1 - 12 of 12 Posts
I'm starting to put together a turbo kit for my 05 2.0 duratec.
I'm going to mount my turbo to my manifold just like a normal turbo setup. I'll be running oil to the turbo from a T-fitting comming off the oil sending unit(thanks for the idea Sporadic).
Can I rout my oil return line to my valve cover insted of the oil pan? My not sure if this setup will couse problems or not. Thanks in advance.
Jesse
Thank you both for the help. Is there an altenitive to running the return to the oil pan?
Discussion Starter #9
Yes i know, I've removed an oil pan or two in my days. Just wondering... Thanks
Jesse
The return has to be below the turbo to drain properly.
Your options are the block or the oil pan.
Good luck and keep up the research.
Discussion Starter #12
Awsome, that gives me a starting point. Thanks alot!
Jesse
1 - 12 of 12 Posts
