1 - 13 of 13 Posts
i just got clutchmasters stage 3 and fidanza 9lb aluminum flywheel, i put about 100 miles on the car, driving it easy, so since i didn't really felt a diff. i got on it a little more tonight, and to be honest i think it was quicker when it was stock, i couldn't get the tires to chirp in 2nd like i used to, i only tried twise, but still, i don't know if there is adjustment needed or maybe it needs more brake in time, i have no clue, my friend chris has the same setup up and he states that is like an on/off switch...
ideas?
thanks
javier
WhiteSTguy
i think the break in period is like 500+ miles before you should start getting on it. i don't know myself, just something that i've heard many times. i'd like to go the same setup in a couple years when i go F/I. i would expect that you should feel a very noticable difference with the rev and acceleration. and with the clutch as well...
Kevlar clutches take significantly longer to break in. 500-1000 miles is a good, safe bet. If you slip it too much early on, they don't like that much apparently. Hope it's still okay :(
hope so too....
so that means that after let's say 1k on the clutch, is going to start gripping like it should???
Yah, stg3. is goofy with break in. Mine wore out quick too....
My stg4 is awesome. 4 puck sprung hub.
the CM stage 3 is a kevlar like the spec stage 2 I put in. Don't hot rod it too much until about 500-1000 miles, I was told you can warp the disk if it gets too hot during the break-in stage. You'll notice a big difference in how hard it grabs. My car hardly ever grabs in first gear anymore since I put the clutch/flywheel in.
Also, as far as chirping the tires into 2nd, sometimes I can really break the tires loose, and some other times, it will just slam into 2nd with no chirp. I think the revs dropping so much faster means you have to shift that much faster to get a good chirp
As far as the clutch grabbing like it should, after I put on my Goodyear GSD3's I couldn't chirp second with the stock clutch. I can do it just fine with my current setup (CM stage 3, Fidanza fly) and the same tires. It will even do it from time to time short-shifting @ around 5k when I really nail a good shift
To me my focus just has its "days". Sometimes when i get in her she feels sluggish and I cant get chirps out... other days all she wants to do is run!! The other day i got in her and the same exact street i go down i usually get alittle bit of a chirp if i get on her... I got on her *shift* and the tires broke loose for a good 3 seconds...
Just my input.
I can get mine to chirp third. [dunno]
Discussion Starter #12
lol [:D]
i went for a ride before and it feels a little better, i just wish i could start it with out pushing it down my driveway....
WD40 said:
^^^Show off. [:p]
I was doing it out of Turn 11 at Infineon all day. [:D]
1 - 13 of 13 Posts
