1 - 3 of 3 Posts
I am pretty much completely done with the PW install with the exception of 1 thing. I need to wire up the pump relay. I know there is a ground wire that you have to ground to the body, a wire that goes to the battery, but the other wire is supposed to go to an ignition hot, where can I find an ignition hot? I know that it is probably not the way the powerworks kit was originally set up but the previous owner modified it I believe.I need to find an ignition hot source. Can someone help me out?
Thanks,
James
Just try to fined the bigger size yellow wire by the sterring column under the dash. or if you have a meter you can turn the ign on and see which wire makes it light up
Thanks Roush I believe there is an ignition hot to the Idle Air Control but I don't know which wire is the hot can anyone confirm this or better yet tell me which wire is the hot?
1 - 3 of 3 Posts
