1 - 19 of 19 Posts
· Registered
I wouldn't even mess with that Ebay trash, unless it is Laminix. I used a can of Nightshade for my tails, came out really good. There is a how to in the Exterior mods section.
· Registered
me and my buddy tried on my friend xB and let me tell u
[:)][:)][:)][:)][:)][:)]* that
we tried many times
all different styles of how to do it
precut,none cut
only way to do it is get them professionally done
and dont go cheap
or u can be like the rest of us and get the nightshade spray
mines gettin in in about a week
and check out snackmasters post on how to
· Registered
Discussion Starter · #9 ·
· Registered
I have heard that it is actually harder to get the precut ones to stay on right, or at all. Sometimes the "precut" isn't right, or there are bubbles, and it fades after a while too. None of those problems are gonna happen with the nightshade. The nice thing with nightshade is if you mess up, hit it with a wet sand and 800 grit and let it dry then do it again.
· Registered
i got my tint spray off ebay.. £10 and came out fine, still havent faded or anything... i put lines in mine too make them different, u can kind of see them in this pic...
· Registered
this was the stuff i got...
http://cgi.ebay.co.uk/BLACK-TAIL-LI...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
(this is an english 1 as i am english but im sure the american stuff should be the same)
but when i did it i just took them out and washed them down then sprayed them i didnt sand them down, if i were to do them again i would sand them down to get the best finish. and it also says to only do around 3 or 4 coats i had to do about 10 before they looked dark and i used a hair dryer after i had sprayed just to speed up the process.
hope this helps
· Registered
this is 1 of my lights up close, u can spray the hole light obviously which i think now would look better but i thought ide be different and put stripes and the police r tight about stuff like tinting lights around here so i wanted to be certain :). this was just the £8 can of spray.
1 - 19 of 19 Posts
