Hey guys,
So my power steering stopped working about two weeks ago and I finally got some time to take a look at it today. I got under the car and I noticed that the fluid pretty much just pours out now. It's coming from the spot right where the high pressure line (I think- the smaller/narrower one that joins the pump on the underside) meets the power steering pump.
So- if this is my problem, what needs to be replaced? Is it possible that just the fitting (it's an 18mm bolt i think, it's a total bitch to get to from under the car, i don't even think it's possible to remove it without taking out the whole pump) and some sort of seal is bad? If so, can I just replace that? Or do I need to do the whole HP line? Or the whole pump? Or both?
What do you guys think? What else should I be looking at to figure this problem out?
Thanks in advance...
