1 - 20 of 27 Posts
So, i was gonna put a procharger on my svtf and so i figured that id get a comp/leakdown test. the leakdown came out alright but the comp test was pretty low. about 100psi or something. is this normal? would i have any issues putting the procharger on top of it?
Edit: Cyl1: 100 Cyl2: 105 Cyl3: 105 Cyl4: 105
Thoughts? suggestions?
Thanks ahead of time guys.
Focused Focus
Did you test that engine cold?
i didnt test it, had a shop do it. but yes the current temp is 60... not to mention altitude about 6K above sea level
Focused Focus
No, no, i mean did they test the engine while it was completely cold? Not warmed up or anything?
hey how much did that cost? i'm looking into doing that before i boost too.
$100. and i couldnt tell ya b16 why is that not right?
Focused Focus
The indicated compression pressures are considered within specification if the lowest reading cylinder is at least 75 percent of the highest reading. Refer to the Compression Pressure Limit Chart.
Compression Pressure Limit Chart Maximum Pressure Minimum Pressure Maximum Pressure Minimum Pressure Maximum Pressure Minimum Pressure Maximum Pressure Minimum Pressure
924 kPa (134 psi) 696 kPa (101 psi) 1131 kPa (164 psi) 848 kPa (123 psi) 1338 kPa (194 psi) 1000 kPa (146 psi) 1544 kPa (224 psi) 1158 kPa (168 psi)
938 kPa (136 psi) 703 kPa (102 psi) 1145 kPa (166 psi) 855 kPa (124 psi) 1351 kPa (196 psi) 1014 kPa (147 psi) 1558 kPa (226 psi) 1165 kPa (169 psi)
952 kPa (138 psi) 717 kPa (104 psi) 1158 kPa (168 psi) 869 kPa (126 psi) 1365 kPa (198 psi) 1020 kPa (148 psi) 1572 kPa (228 psi) 1179 kPa (171 psi)
965 kPa (140 psi) 724 kPa (106 psi) 1172 kPa (170 psi) 876 kPa (127 psi) 1379 kPa (200 psi) 1034 kPa (150 psi) 1586 kPa (230 psi) 1186 kPa (172 psi)
979 kPa (142 psi) 738 kPa (107 psi) 1186 kPa (172 psi) 889 kPa (129 psi) 1303 kPa (202 psi) 1041 kPa (151 psi) 1600 kPa (232 psi) 1200 kPa (174 psi)
933 kPa (144 psi) 745 kPa (109 psi) 1200 kPa (174 psi) 903 kPa (131 psi) 1407 kPa (204 psi) 1055 kPa (153 psi) 1055 kPa (153 psi) 1207 kPa (175 psi)
1007 kPa (146 psi) 758 kPa (110 psi) 1214 kPa (176 psi) 910 kPa (132 psi) 1420 kPa (206 psi) 1062 kPa (154 psi) 1627 kPa (154 psi) 1220 kPa (177 psi)
1020 kPa (148 psi) 765 kPa (111 psi) 1227 kPa (178 psi) 917 kPa (133 psi) 1434 kPa (208 psi) 1075 kPa (156 psi) 1641 kPa (238 psi) 1227 kPa (178 psi)
1034 kPa (150 psi) 779 kPa (113 psi) 1241 kPa (180 psi) 931 kPa (135 psi) 1448 kPa (210 psi) 1083 kPa (157 psi) 1655 kPa (240 psi) 1241 kPa (180 psi)
1048 kPa (152 psi) 786 kPa (114 psi) 1255 kPa (182 psi) 936 kPa (136 psi) 1462 kPa (212 psi) 1089 kPa (158 psi) 1669 kPa (242 psi) 1248 kPa (181 psi)
1062 kPa (154 psi) 793 kPa (115 psi) 1269 kPa (184 psi) 952 kPa (138 psi) 1476 kPa (214 psi) 1103 kPa (160 psi) 1682 kPa (244 psi) 1262 kPa (183 psi)
1076 kPa (156 psi) 807 kPa (117 psi) 1282 kPa (186 psi) 965 kPa (140 psi) 1489 kPa (216 psi) 1117 kPa (162 psi) 1696 kPa (246 psi) 1269 kPa (184 psi)
1089 kPa (158 psi) 814 kPa (118 psi) 1296 kPa (188 psi) 972 kPa (141 psi) 1503 kPa (218 psi) 1124 kPa (163 psi) 1710 kPa (248 psi) 1202 kPa (186 psi)
1103 kPa (160 psi) 827 kPa (120 psi) 1310 kPa (190 psi) 979 kPa (142 psi) 1517 kPa (220 psi) 1138 kPa (165 psi) 1724 kPa (250 psi) 1289 kPa (187 psi)
1110 kPa (161 psi) 834 kPa (121 psi) 1324 kPa (192 psi) 993 kPa (144 psi) 1631 kPa (222 psi) 1145 kPa (166 psi) — —
Focused Focus
Thing is guys, if you want to do a compression test, before you pay $100+ for a test, you can buy a halfway decent tester and do it yourself for that much money and have the tool if you ever want to do it again. Thats not the best gauge, but one thats good enough for the average comsumer for personal use.
Discussion Starter #9
cool... so 75% of 105 = 78.75.
So i should be good then cuz the 5psi difference is only like 4% difference
Focused Focus
The engine should be tested at after its warmed up a bit. Im sure if you took it to a good shop it was done correctly, but those numbers seem low. You can try this also.:
If one or more cylinders reads low, squirt approximately one tablespoon of engine oil on top of the pistons in the low-reading cylinders. Repeat the compression pressure check on these cylinders.
Compression Test—Interpreting Compression Readings
If compression improves considerably, piston rings are faulty.
If compression does not improve, valves are sticking or seating incorrectly.
If two adjacent cylinders indicate low compression pressures and squirting oil on each piston does not increase compression, the head gasket may be leaking between cylinders. Engine oil or coolant in cylinders could result from this condition.
Use the compression pressure limit chart when checking cylinder compression so that the lowest reading is within 75 percent of the highest reading.
yeah so basically that sounds very confusing to me. i plan on going the turbo route, but have considered the cfm shortblock since the miles are getting up there. however, if i'm replacing the pistons, rings, rods, and head, is there anything i should be worried about with compression or wear?
Discussion Starter #12
i think its a good shop. i feel comfortable with them. its the same guys that fixed my exhuast powersteering and radiator issues on the non-svt.
so, b16 i just wanted your advice for the moment. I've got a procharger on the way, i think im going to be running the 8lbs for a while so that i can run the stock MAF. The kit comes with 42lbs injectors so i really just need a tune. That should hold me over for a while right?
I just have to ask why it needs to be warmed up to do this test? A compression test is just that testing for compression.
Could it have to do with the oil being up to temp?
that would afffect the way the rings seat
blkthunder
I have a 8lb procharger kit. I started with 42lb injectors but have moved on to 60lb injectors. You might want to get a Kenne Bell boost a pump also. Not saying you need it but someting to think about. You will also need Diablo sport MAF or a bigger MAF.
Good Luck
Focused Focus
Yes, you should be ok with that. The question of compression and a cold engine, the pistions and rings expand with heat and will affect the compression levels. Its a slight difference but does make for different readings.
Focused Focus
If you dont mind me asking, where did you get the Procharger kit?
Focused Focus
You can also use a Lightning maf and a Cobra iat. You can usually get these a little cheaper than the MAFiA from Diablo.
Discussion Starter #19
from piranahsc... didnt that used to be your kit?
I have a compression tester.. ITs very easy and most come with simple to follow instructions. Best $30 i ever spent (especially dealing with the 4 DSM turbos i had)
1 - 20 of 27 Posts
