1 - 8 of 8 Posts
So what problems should i expect when i finish my turbo project? My car will go under the knife in a few weeks.. I wanna to know what to expect besides blowing my motor but im having a good tuner tune it.
Make sure you have a bead roll on all the ends of the tubes to prevent them from blowing off under boost...thats the best non-svt advice I can give..
FF Affiliate
I dont agree, I make about 25+PSI and never have them blow off and dont have a bead on any pipes
If the piping is clean and the hose is a quality hose then they will stick and wont come off
The BIGGEST problem I've seen is most peoples right foot starts turning to lead.
what if its already lead?
I agree 100% - you even advised me to use a brake cleaner, and sand paper and it worked GREAT! A Bead roll is just a precautionary measure.
Discussion Starter #8
Well my piping already have a bead. What do you mean about lead? Are you reffering to the fuel? Another Q's will my stock fuel pump hold up to 10lbs of boost? Can i expect fuel cut?
1 - 8 of 8 Posts
