1 - 17 of 17 Posts
So I currently have the Eibach Pro-Kit Springs matched up with the KYB AGX's. I have about 60k miles on this setup and one of my front struts is leaking and one rear strut is blown.
I have been more than satisfied with my current setup but if I am going to have to swap struts, I want to go with some Koni Yellows. While I got the car up in the air I thought I could also change my springs as well.
The Pro-Kit does a very good job of lowering the car, but the spring rate is pretty close to the OEM SVT spring rate. I was looking for a better (firmer) spring rate while also keeping the height I currently have now with my 60k mile Eibachs.
I have spent the last couple of months skimming the forum and I have two options.... 1) H&R Springs / Koni Yellows OR 2) ST Coil-Overs by KW
Price-wise, they are within $200-$300 of eachother.
QUESTION
Which H&R Spring do I want that is comparable to the Pro-Kit?
RIDE HEIGHT
H&R O.E. Sport = SVT OEM-ish
H&R Sport = Eibach Pro-Kit
H&R Race = Eibach Sportlines
I am running sportline springs with my eibach kit. If you go sportlines be prepared to feel everything on the road. I feel every bump, the only benefit is when I drive the canyons it handles great and worth it
Sent from my ADR6300 using Tapatalk
soon to be turbo!
Sent from my ADR6300 using FF Mobile
you think the sportlines are stiff, try the H&R race! with those you will feel paint lines and if you go down back roads at 70+ you feel like your only doin 50ish.
my suggestion is go with the koni yellows and H&R race. plus the set is like 800 bucks and is almost as good as a coilover set.
FWIW the H&R Race springs are not anywhere comparable, except maybe in resulting ride height, to the Eibach Sportlines. Sportlines are for show, H&R Race for go.
I am not interested in Eibach Sportlines, I already have the Pro-Kit and want to change to the H&R Springs.
Eibach springs lower the car, and that is pretty much it. The spring rate is comparable to an OEM setup. So all it is, is a shorter spring.
I am looking for a shorter spring, while having a more firm spring rate than OEM / Pro-Kit.
I had a feeling it was going to be the Race version of the H&R's.
Geezer, from what I have found, it seems as though the ride height aspect of the H&R is as follows.....
RIDE HEIGHT
Discussion Starter #8
I don't see the H&R Race Springs ONLY on TireRack.com.
Where can I find just the springs, and not the Kit??
The only option that comes up is the H&R Sport Spring set.
w/ my magic bag
Do you really need race spring's? What about H&R's "sport cup" kit?
Discussion Starter #13
PARTS HUNTER
H&r race is a great setup![thumb] if u want just to lower these are not for u. If u want real performance and handling these are for u. I had sportlines before they are for.looks only. I daily this setup, if its a rough road then its rough, smooth its smooth etc. And when paired with the h&r front and rear 24mm sways its incredible in the twisties.
Discussion Starter #15
Geezer said it best.... Eibachs just lower, but the H&R lower and increase performance, which is what I want.
w/ my magic bag
ST by K/W !
[headbang]
QUESTION
RIDE HEIGHT
I'd go w/ the ST coilover=galveninzed, oh well vs K/W's stainless steel. Tire rack has a good price on thou. I was looking at coilover's too. But went w/ a fixed platform instead, to me, I don't need coilover's for a DD. I put the money in other part's of the car. CFM's front lower stress bar/ Dom's rear chassis brace/ toe-link's, Steeda shifter. I already have Baer brake's, CFM's tubular control arm's, Steeda's rear bar/ 22mm Eibach front bar.
soon to be turbo!
you could buy some coilover sleeves from summit then select what spring rate you want out of the 2.50" spring category.
if i knew they had sleeves at summit i would of never bought my PSS9 system.
1 - 17 of 17 Posts
