1 - 7 of 7 Posts
i would like to bring my idle up to 1000 rpm. the reason is my alternator isnt putting out enough voltage at 900 rpm and i am tired of my lights flickering. when i bring it up to 1k it stops. this is a temporary fix for the flickering until my new alternator comes in. can you adjust idle speed with the predator?
I.S.A.I.K.I.
If you bought your Pred through Tom he might be able to refine your tune for nothing.
Are you running your A/C or defroster controls when this happens? Stock SVTs will do this when those controls are active.
it happens when all accessories are off. all of my connections are solid, i have also upgraded all power cables/grounds. has anybody installed an upgraded alternator and cured this?
I.S.A.I.K.I.
Have you tried checking the condition of the alternator wiring harness? Those usually tend to break before the alternator goes.
FF Affiliate
If you got the Pred from me I will be glad to raise the idle for you , If you didnt and have the Diablo STD Performance tune for 125.00 you can get my custom tune with better performance gaines and raised idle
1 - 7 of 7 Posts
