1 - 5 of 5 Posts
I have a small problem with the shift cables on my powerworks install. Both cables are running underneath and touching the supercharger bypass valve and hanging dangerously close to the flexpipe. There seems to be a lot tension on them. They can't fit on the passengers side of the bypass valve. They aren't long enough. On the driveride there is a vac. line fitting. Where should these cable be running?
Mark
Car is up and running. Still have issue with shifter cables. They are binding. Can anyone take a look at their car and let me know how your shifter cables are running?
Problem solved. miss routed intercooler coolant hose was the problem.
1 - 5 of 5 Posts
