1 - 5 of 5 Posts
i have a 05 focus ses zx4 and the main switch works to control the front driver side window but doesn't work the other three windows. all of the other window controls work by themselves independently. what could be the issue or problem?
i would try and look at the wires in the left front door joint (where the wires go from the body to the door) it happens often that those wires get skinned, shorted or even cut with the years of opening and closing the doors. if not try to jump the wires in the connector of the FL switch to open/close the windows directly if it works your main switch is dead.
Reference: 2004 Ford Focus Wiring Diagrams manual
mind you the 2005 could be different
Two fuses: both located in the central junction box
F2.55 25 Amp and F2.54 25 Amp
It is a common problem that the wires inside the umbilical going to the hatch crack/open/short
So maybe the wires inside the door umbilicle might be going bad also
Discussion Starter · #4 ·
what if the wires are good could it be the main driver side switch itself the could be the problem.
1 - 5 of 5 Posts
