I posted a couple of weeks back that the tailgate wasn't locking when the remote was used. I followed the suggestions, mechanically everything seems to be fine. The owner's manual was no help. I determined it will lock but I must cycle through the lock process 4 times. That tells me mechanically things are working but electronically there is a problem. Also, the key will unlock the tailgate [1/4 turn to the right] but the lock cylinder does not go to the left to lock it. Is that the way it was designed? Is there a "reset" for the remote locks?
Here is how the remote works presently:
-1 push on remote lock button locks doors, second push sounds horn. Tailgate
does not lock but doors lock
-Second sequence of above, 4 pushes total, locks tailgate.
-Tailgate unlocks with the button specifically for tailgate.
-Tailgate unlocks with the doors, 2nd push of unlock button.
So the only part of this sequence that is wrong is locking the tailgate. How was it designed to work? I expect tailgate to lock with the first push of the lock button on the remote instead of 4 pushes.
