Moved to "General Technical Chat". If you have the 1.6L or 2.0L Zetec motors, the high pressure power steering line runs across the top front of the motor over the exhaust manifold. If you have a Duratec motor, I am not exactly sure as to where the power steering line runs.
The high pressure line on the Zetec runs from the power steering pump, over top of the exhaust manifold on the front side of the motor, then turns to go over the transmission bell housing to the power steering rack. There is a bolt on the backside of the power steering rack that connects the power steering line to it. There is also a slotted key that fits over a square post on the steering rack. You have to make sure that key is lined up on that square post before you can tighten down that bolt. If you don't line it up, you will spray power steering fluid all over the engine bay.
