1 - 3 of 3 Posts
2000 Ford Focus
4 months ago I added some power steering fluid up to the max level. Today the fluid is 1cm below the Min level. I just checked the car chassis, and no fluid is leaking. Please give me any idea where it is leaking to? Thanks a lot!
Flat Black King
maybe there is a leak its just right there. check by ur brakes or something.
Check your low pressure lines coming from the resevoir. I had a 97 Contour that sprung a leak in one...took me a month to find out exactly where it was at. It ended up being a pinhole leak in the tubing that ran up to the cooling loop by the radiator. If it's a leak on the high side you'd know where it was by know...
1 - 3 of 3 Posts
