When I first bought my used 2010 FF, the doors and locks operated fine, then the right rear door wouldn't unlock intermittently. This ghost problem seems to come and go migrate around between the passenger and both rear doors. Currently the passenger and right rear door won't open. Do you think this intermittent problem is somehow affected by the CompuStar AutoStart which also has a key fob that locks and unlocks doors?
I have tried all key fobs as well as the unlock switch on the door panel even while pulling up on it at same time I push unlock button. Do you think if I unhook the CompuStar that it might solve the problem?
Some other posts have suggested it might be an actuator problem, but why will they work sometimes and not others?[
