1 - 4 of 4 Posts
Hi guys, it's nice to be here, great site for info. So, I'm about to purchase an 02 ZX5 but it needs a parking brake cable and the rear control arm bushings done. Where is the best place to get these parts from? I'm in Canada BTW. Thanks in advance.
Welcome
You'll find a Ford & an Aftermarket source in out "Vendors" section for discounted parts.
The rear end will require new arms to get new bushings, check out the Brakes, Suspension & Chassis section for more hints on that PITA of a job. (cutting out old bolts & replacing them is usually needed)
Thanks for the response. So I actually went and bought the car today. Found out exactly what the bushings are and they are only the endlink bushings for the rear sway bar. Should be an easy fix. The next thing is the passenger front door won't unlock, any tips on that?c
1 - 4 of 4 Posts
