1 - 20 of 33 Posts
hey can you guys post your pics of your cai i bought 1 and on the instructions there arnt any pics and if anybody lives in southern cali does anybody know any shops where i can get my tb,cai,udp's installed b/c i tryied 2day and i still have a headache all i have to say is i hate american cars there's no reason why we need 2 use 5 different screw for the same part so can you guys please help me out
WhiteSTguy
give me some time tomorrow morning and i can take pictures of all of it so you can see better pictures of the mounts and all. i can do that when there is light out.
i installed mine without any instructions. if you have basic understanding of how things go together, it's pretty easy as everything just fits right together.
alright thanks when u were installing it did you have to take out the battery and stuff and did you remove the whole filter system even the bottom b/c i had problems taking that out there's like a hug bolt in the middle and it wouldnt come out i think the size was a 13 well get back to me or pm me b/c i really need help
WhiteSTguy
yes you will need to remove the battery. as you can see i removed the whole intake system. you will need the angle piece that where the hose connects to the bottom of hte intake filter box. that will clip onto the hose that came with aem kit and will snap into the new intake pipe. i'll take pics of that as well tomorrow. make sure your battery will be disconnected for at least 15 minutes so when you hook up your new cai, the computer will learn for the increase in air coming into the engine.
Do not remove that bolt under the old air intake box, it is a major engine mount and you will drop your engine.....not good......
Discussion Starter · #6 ·
ok so the intake goes in between the battery and engine mount right ??
WhiteSTguy
hey let me check old pictures, i just remembered taking them as i was installing this.
Discussion Starter · #8 ·
alright but yea the other problem i was taking all the parts and filters off the car and you guys know the hose that connects the tb to the filter that clamp i never seen b4 most clamps have screws to unscrew but mine didnt have a screw it looked like it was bent or strapped on i didnt know how to get it off you guys wait a couple of min imma take a pic of it and put it on here i didnt know if there's a certain tool to get it off or if i need bolt cutters
Titular Wit Here
This really isn't that hard of an install, to be honest... and I think the type of clamp you are talking about is the kind that you take off with pliers, you just squeeze it with the pliers to open it enough to remove the hose.
WhiteSTguy
ok here they are...
WhiteSTguy
no i think he's talking about the crimp clamps. those just come off i think they are one time clamps. just go to autozone or sears hardware and buy some nice 3" hose clamps.
Discussion Starter · #12 ·
yea i cant get this clamp off tho look
<center>
<a href="http://i11.photobucket.com/albums/a172/superfly092886/DSC00051.jpg" target="_blank">
<img src="http://i11.photobucket.com/albums/a172/superfly092886/th_DSC00051.jpg"></a>
<a href="http://i11.photobucket.com/albums/a172/superfly092886/DSC00050.jpg" target="_blank">
<img src="http://i11.photobucket.com/albums/a172/superfly092886/th_DSC00050.jpg"></a>
</center>
WhiteSTguy
yeah just pry those off superfly. they have little clips on them that lock them onto itself.
WhiteSTguy
needle nose unless you want to get the special pair of pliers to take them off[:D]
or just stick a flat head screwdriver inbetween the lock and pop it apart. either way works
Titular Wit Here
My mistake, for some reason I thought he was talking about the breather hose... [:I] Duh.
Unless you are planning on possibly reinstalling the stock air intake, or selling it, you don't need to worry too much about those clamps. Just take your time and don't rush it, you should be able to do this with basic hand tools.
Discussion Starter · #19 ·
sorry guys i went 2 c fast and furious good movie i liked it but imma try later and ill get back on 2 u guys if i have any other problems
Jeez this shouldn't be a multi-day project. You also don't have to remove the entire battery support, just the battery itself.
Band clamp removal:
1. Pry the yellow part up and away from the red part so they no longer clasp together. You must do this from both sides of the clamp so it fully disengages.
2. The purple dot is a tab sticking up through a slot, which is green in the diagram. You need to slide the tab to the end of the green slot. I used a flathead and a blunt object.
Done.
1 - 20 of 33 Posts
