1 - 20 of 55 Posts
Does anyones rear door sill collect water after a rain? I'll open the door after the cars been sitting after a rain and water pours out. I'm thinking this might pose a problem in the winter. I flintch too when someone I'm driving closes the door.I've reverted to say when people get out....don't slam the door.
I've read about that problem on a few threads. I don't have my car yet though, so nothing first hand.
Sent from my ADR6300 using Tapatalk
Yep, me too. Water gets into the little cubby next to the seat as well. My rear hatch leaks and some foam piece in the front on the driver's door jamb between that and the wheel well is loose and dangling around. I think that may be for sound deadening, though. Those are the least of my issues, unfortunately.
Out of curiosity, is this on the passenger or drivers side, or both?
Yep, I noticed that when I first got my car (~mid-May), only on the right side, though. It seemed to be holding quite a bit of water after a heavy rain.
I will keep an eye on it...if it continues, I'll bring it up w/the dealer.
Discussion Starter #9
Both sides, but the passenger side mostly. Maybe the doors need adjusting.
Discussion Starter #10
It's definitely caused by all the door slamming [spank]
The doors don;'t weigh anything. When my daughter closes the doors my ears ring[:)]
You can close them with your little finger they're so light.Not that that's a bad thing.
Discussion Starter #11
I think mines mosly on the driver side and less on the passenger side. I'll probably do the same. I can picture the doors freezing in the winter.
Hi, I think the water isn't actually collecting on the sill but is coming out of the door drains and is prevented from draining away until you open the door...
Chris
The water comes out of the door drains, travels down to the bottom of the door edges and gets trapped because the door metal is not folded all the way over at the bottom of the door (it's an open V shape when viewd on end). This is the only car I've had like this and think this area will plug up with dirt pretty quickly and cause premature corrosion. I filled this gap on mine up to prevent dirt and water getting in there in the first place (Shoe Goo or clear silicone caulking) but at the very least I would keep it clean and well oiled with spray can oil(which I didn't do because I didn't want oil drips along the lower matt black plastic trim piece).
Discussion Starter #14
Chris
That makes sense Chris. Thanks, I think you nailed it.
Hi, it is the same for my Mk4 Mondeo, must be in the design..
Chris
Hi, so if you open the door water doesn't drip from it then? I see what you are saying, perhaps if you can post a photo of the issue you are talking about so we all know where to look...
Chris
Hi, so if you open the door water doesn't drip from it then? I see what you are saying, perhaps if you can a photo of the issue you wish to ilustrate might be more explanatory...
Chris
Chris
I think what Chris is saying is the reasoning why this is happening but for sure a picture would definitely help get to the bottom of it.
Hi, thank you for your help, I saw my bad grammer and edited my post anyway.
Cheers,
Chris
Discussion Starter #20
I'll have to look into it further. Sorry I can't take pictures right now. I deleted my bucket account.I need to go in and re activate it or make a new account.
1 - 20 of 55 Posts
