1 - 5 of 5 Posts
Wings & Teeth
fuel pump
will work for the svt engine?
or am i dumb for thinking this
I'm not positive, but I do believe you need the SVT fuel pump or you run into fuel starvation at upper RPMs.
I believe the SVTF fuel pump is the same as what's in a Mustang right? So I'm going to say no you can't use a Zetec pump.
fuel pump
I just done an svt swap and im using the stock zetec pump and I ran it open header for a few days and got a check engine code saying it was too lean or too rich so I put the 02 cheater on thee and got the same results. slapped the rest of the exhaust on there with a full tank of premium and haven't had a problem since then
Just do it the right way... or you could upgrade to a Ford GT pump.
1 - 5 of 5 Posts
