Hi everyone, over the last few months I've been having some bad issues with my car. Every once in a while, it wouldn't start and simply removing the battery terminal and putting it back on would fix the issue. Then, I tried doing the same yesterday and I couldn't get the car to start at all. Someone tried jumping my car and I still got nothing.
Yesterday, the speedometer would gently bounce when the key turned, but there was no click/crank/etc. just silence. The electrical would kick off for a few seconds and then kick back on. I took my DMM outside and measured 13.38V on the battery which implied it was still in decent shape (I know you need a load tester to properly test, but it was just too see). The battery was purchased August 2013.
I then tried starting my car and it started right up, so I went and ran a couple of errands. Right before I got back, the engine started stuttering and a minute or so later just died, but I managed to pull off into a parking lot. The dash lit up and my odometer went blank, showing dashes on both levels. I then had the no crank no start condition again so I just walked the half mile or so back. Does anyone know what might be the cause of this? My Focus is completely stock except for an aftermarket stereo.
Pictures of engine and dash:
