1 - 5 of 5 Posts
The Professor
I need your opinions. I can do either of these first, then wait and do the other a couple of months later. I can port and shave my head .050, or I can install new Crower Stage 2 cams. My car is a daily driver. Which would you do first?
I have a 70mm mass air with 30lb injectors, a 65mm TB, a ported 2000 intake, a CAI, a UDP, Cam Gears, FC longtube and flex, a Magnaflow exhaust, and a Ford chip. I might have missed something, but that's the important stuff.
The Professor
That's what I am leaning towards too, but I worry about the compression with the wide overlap of the stock cams.
With the cam gears in place you can either butt dyno or take it to a dyno..Its not do hard to redial..after head work!
1 - 5 of 5 Posts
