1 - 8 of 8 Posts
My 02 SVTF has 92,000KM as of today. (around 50K miles) It popped out of 6th gear 4 times tonight. Anybody have this problem? I noticed it has felt "different" latley. Almost harder to go out of 2nd. I shifted faster and harder and it went in fine. But, there shouldn't be effort in that. I see these things happen all the time...First 6th, then maybe third..or 2nd..
I rarley use 6th, but I DO NOT want to buy a $4000USD tanny. And ideas??
Broken cars s[:)][:)][:)] :(
just get a new clutch?!?
Supercharged
It is most likely the shift linkage and or clutch. It could even be the rear lower transmission mount. Not much you can diagnose over the internet.
Your right, not much you can do over the internet.
It was OK today, but I will be adjusting the cables when I put my ORP in. And I don't think I need a clutch. I will do it next spring anyways.
Thankyou
WhiteSTguy
matthewsvt said:
Make that $3057.31USD
i see them go for less the $500 on ebay every now and then... buy are used ones not new.
Discussion Starter #8
hmmmm...thats not as bad. But If I did that, Id also order parts or rebuild one, and then have a spare.
1 - 8 of 8 Posts
