What suspension setup do you have?
  • stock
    Votes: 156 25.3%
  • SVT
    Votes: 127 20.6%
  • lowering springs only
    Votes: 64 10.4%
  • lowering springs and dampers
    Votes: 104 16.9%
  • full suspension kit
    Votes: 102 16.6%
  • coil overs
    Votes: 37 6.0%
  • other
    Votes: 26 4.2%
  • Total voters
    616
101 - 120 of 211 Posts
Ok got a FNG question, what are dampers, and if I install the Eibach pro-kit (1.2 front 1.6 rear) do I need to install new ones ?
My setup=
-Tein S-Tech's
-Eibach Pro Dampers
-Steeda 28mm RSB
BTW Leadf00t, Dampers are your Shock/Struts and no you dont need new ones for the pro kit drop, But it will def complement the springs-
so which is the better route? the eibach sportline, and then the eibach pro dampers, OR, or...the h&r cup kit? which is the better route overall? price, value...ect.
I'm going to be upgrading in the near future (like, next week) to the discontinued Ford Racing/KW springs and KYB AGX adjustable dampers.
well, by later this afternoon i'll be running KW springs w/SVT dampeners. then i'll be ordering the progress rear sway bar next week.
H&r Full Cup Kit
Dampers are the technically correct term for shock absorber. A dampers controls both rebound and compression strokes of a spring. Technically (engineering nerd use) a shock controls one or the other and a spring need not be involved in creating the motion. It became common in the U.S. to use the term shock rather than damper (which is a more common term elsewhere in the world).
And yes, its always advisable to use new shocks /dampers with new springs, especially if the springs are shorter (shorter shock shafts are needed to maintain travel) as well to effectively dampen the increased spring rates shorter springs normally have. Stock shocks may work initially, but they will quickly tire out. You'll never witness the full performance benefits of the new springs unless they are effectively damped. Only a shock specifically designed for use with the shorter/stiffer spring can do that correctly.
eibach prokit springs on stock shocks. looking to buy some KYB's to replaced the worn out front ones for now then later in the futere when i got more $ replace the rear for some KYB's too.
Koni yellow shocks/struts
eibach sportline springs
steeda rear anti-sway
H&R gfront anti-sway
Stock SVT Suspension for the moment.
I'm switching to the Saleen/Racecraft Suspension kit w/ struts, springs, front and rear sways and bushings from the n2o Saleen Focus for a measely $450 US. This is gonna get done PDQ, so I'll keep y'all posted on how it goes, and give plenty of pics/reviews.
