What suspension setup do you have?
  • stock
    Votes: 156 25.3%
  • SVT
    Votes: 127 20.6%
  • lowering springs only
    Votes: 64 10.4%
  • lowering springs and dampers
    Votes: 104 16.9%
  • full suspension kit
    Votes: 102 16.6%
  • coil overs
    Votes: 37 6.0%
  • other
    Votes: 26 4.2%
  • Total voters
    616
201 - 211 of 211 Posts
Thats What She Said
Front:
Eibach Front Swaybar
Koni Yellow struts with H&R Race Springs w/ LCR Race Camber plates
C-F-M Front Tubular Control Arms
Massive Swaybar Links
Full Poly bushings
'05 "upgraded" knuckle (larger ball joint)
Rear:
Massive Rear Toe links
Massive Rear Lower control Arms
Massive Rear Camber Arms
PAC Racing 450 in/lb 3" x 6" srpings
Eibach Rear Sway Bar
Full Poly Bushings
Koni Yellow Rear Shocks
w/ my magic bag
You ever get your CFM A-arms figured out?
Yea... But not sure what problem I was having... I had a hard time getting one of the heim joint to unthread but with a but of heat it was easy to Remove, added anti-seize and painted the arm.
Got the front camber to - 4 degrees in the front and - 2ish in the back. Handles on the track well and so far seems to be good tire ware and gets even heat in the tire.
