I'm seeing evidence of oil getting in that tube- is that correct? If so, then you need a new valve cover gasket, and a new set of plug wires. You can try cleaning the plug wires, but you might not get all the oil and crud residue out of it, and even cleaners will leave a conductive residue. In fact, that was one of my spark plug wire tests- spray some sort of soapy household cleaner Fantastic or Purple cleaner on the plug wires, start the engine at night, and look for sparks in time with engine misses. That's one way to detect bad plug wires. The AM radio method is just easier.
Did you clear codes to see if the DTC came back? What was your plug gap? I might also be seeing evidence of burning on the insulator- does that look like deposit buildup or scorching to you? It's difficult to tell from here. If you think it might be scorching, then you could need a new coil. Sometimes when coils go bad they allow high current spark instead of high voltage which scorches the insulator and causes misfire. My wife's van did that, I kept replacing the offending plug, and it would screw up again in less than a day until I replaced the coil. That one condition you'll know if you have it because you can clean the plug, re-install it, even install a new plug, and it will fail in the first day. New plugs with this coil failure condition will show scorching after misfiring- it will be more obvious than on the older plugs.
