I was basing procedure on 2005 procedures. Sometimes they are similar plus minus a year either way. It looks like this, but he uses a different name. He calls it a power steering pump. The ALL DATA calls it Air conditioning compressor. It is possible that he called it by the wrong name?
How to replace a thermostat in a 2005 Ford Focus
https://www.youtube.com/watch?v=7WL3PYyBoC8
@ 3:25- 4:10 Engine mount obstructing accessory belt bolt, reason for removal of Engine mount. However he didn't mention supporting vehicle underneath with board between jack and oil pan. SO that engine doesn't fall or slip position while removing. At least I didn't hear him say that.
@ 4:10- 4:27 forwards he talks about power steering pump removal and set aside do not disconnect hoses. In Alldata and Haynes manual it says part is called; an AC Compressor
Then it says go to remove cooling fan motor and shroud in Haynes and ALLDATA manuals?
When I compare my 2006 engine layout to what is shown in video above it looks identical. I wonder why they would call it a Power Steering Pump- When its an AC COMPRESSOR? Does AC compressor and Power Steering pump mean same thing?
Cooling fan and shroud? Is this just merely disconnection of some connector pieces of is it liken to removing a auto part in its whole? Now you can see how I am confused. If it can be narrowed down more about what to expect would be nice.
1. Loosening of ACCESORY BELT? What would expect when its put back together? How tight should it be is there a tool or just go by feel? How will I know that Serpentine belt doesn't slip off of something in process? As you are aware the tension is loosened or is it not enough to cause the configuration to be changed?
2. Coolin Fan and Motor removal procedures? Unclear what this means.
So in recap what is unknown is steps for ensuring proper reassembly of ACCESSORY BELT. In consideration of bolts retightened for AC COMPRESSOR. Im going to call it an AC COMPRESSOR as the Haynes manual and alldata have yet to do me wrong. Additionally COoling fan motor and shroud? How do I do this part? I believe I completely understand all other steps. Don't mean to sound redundant in explaning this. Just showing why I was saying what I said what it was based off of. WHile attempting to point out where unclear of something. Perhaps anothers insight would clear up my confusion such as yours interpretation of what I found.
Thanks Again,
Somethin2
