1 - 7 of 7 Posts
Well it finally happened.
I knew it would.
Everyone seems to have a problem at one time or another with their Focus, but I didn't really think it would be this soon. After only 4 months and 6000 miles I'm getting a PO 135 and a PO 141 code.
PO135---- Upstream heated O2 sensor heater circuit fault (Bank 1)
PO141---- Downstream heated O2 sensor heater circuit fault (Bank 1)
I had the code cleared, but it returned upon start up.
I am dreading my first encounter with the Ford dealer service dept and all the hassell that it entails.
Anyway, I was just wondering if anyone has had any experience with this error code or if there is a recall or anything related to these codes.
2004 Focus SVT with 25,000 miles.
Thanks for the input,
NCFazer
I can run your VIN of your vehicle and check for that recall or tsb for you but it seems that it may be your CAT causing the issue. When you get a chance let me know.
Thanks
Thanks for the offer of help. It would be good to go into the dealership with a little more knowledge. The shield on my catalytic converter did fall off so maybe that has something to do with it.
the VIN # is: 3 F A H P 3 9 5 8 4 R 1 2 4 3 9 6
Manufactured on 3/23/2004 Build # 1742
Will this research indicate if any warrantee work has been performed on this car??
Once again, Thanks,
NCFazer
I am going to EMAIL you all your INFORMATION maybe that will help you.
PM with your EMAIL ADDRESS and i will send you everything you need to know to help you solve this.
Let me try and help you out some more really quick by giving you a PINPOINT TEST that you might be able to follow since your able to grab your codes from your vehicle.
Just Follow the Pinpoint test until you need to stop or until you find the problem i will list the whole thing. Hope this helps.
H11 PERFORM KOEO THE ON-DEMAND SELF-TEST
Key ON, engine OFF.
Are any of the following DTCs present: P0135, P0141, P0147, P0155, P0161 or P0167.
Yes - Key in OFF position. GO to H12 .
No - Key in OFF position. GO to H13 .
H12 DTCS P0053, P0054, P0055, P0059, P0060 AND P0061: CHECK FOR VPWR IN THE HARNESS
Note: If DTCs are present, test their related circuits individually.
HO2S connector disconnected.
Key ON, engine OFF.
Measure the voltage between:
( + ) HO2S Connector, Harness Side ( - ) HO2S Connector, Harness Side
VPWR SIGRTN
Is the voltage greater than 10.5 V?
Yes - GO to H13 .
No - REPAIR the open circuit.
Check fuses.
H13 CHECK THE HO2S HEATER FOR SHORTS IN THE HARNESS
PCM connector disconnected.
Note: If DTCs P0053, P0054, P0055, P0059, P0060 or P0061 are present, test their related circuits individually.
Measure the resistance between:
( + ) HO2S Connector, Harness Side ( - ) Vehicle Battery
HO2S Heater Negative terminal
HO2S Heater VPWR
HO2S Heater SIGRTN
HO2S Heater HO2S Signal
Are the resistances greater than 10K ohms?
Yes - GO to H14 .
No - REPAIR the short circuit.
H14 CHECK THE HO2S CIRCUIT FOR AN OPEN IN THE HARNESS
( + ) PCM Connector, Harness Side ( - ) HO2S Connector, Harness Side
HO2S Heater HO2S Heater
Is the resistance less than 5 ohms?
Yes - GO to H15 .
H15 CHECK THE INTERNAL RESISTANCE OF HO2SHTR
( + ) HO2S Connector, Component Side ( - ) HO2S Connector, Component Side
HO2S Heater VPWR
Is the resistance between 3 ohms - 30 ohms?
Yes - GO to H16 .
No - INSTALL a new HO2S.
H16 CHECK THE HO2S CASE FOR A SHORT TO VPWR, HTR AND SIGRTN
HO2S Heater SIGRTN
( + ) HO2S Connector, Component Side ( - ) Vehicle Battery
Is the resistance greater than 10K ohms?
Yes - INSTALL a new PCM.
i had those exact same codes! help me too please
then i installed my header and flex and i got the p1131 can anyone help me with that??
P-1131: sensor indicates lean
i have a P0147 code right now. and its killing me i know if from my header cause i have a OBX and it only calls for 1 o2 sensor spent 400 on a tune and tune never got rid of it. So now im stuck driving around with the cel light on till i get it fixed.. Any help will be great
1 - 7 of 7 Posts
