1 - 6 of 6 Posts
im installing my jrsc+bbk myself and i need some help. does anyone know how to hook up the vac lines? there are 4 nipples on the sc and the directions only show a sc with 2 nipples. and the hoses dont fit so im getting kinda frustrated. what lines do i hook up and where? basically info on hooking up the whole vac system would be great.
thanks
ben
Discussion Starter · #2 ·
can i reuse the stock ones that looklike skinny wires with plugs on the end? they fit perfect
doesnt anyone have pics of there setup? just need to know how to hook up the vac lines.
Discussion Starter · #4 ·
also what should the gap be for the new copper plugs?
FF #1 Most Wanted
1.
I only have 2 vac nipples on top next to the TB opening.
The install directions are pretty self explainatory but here's a pic of mine.
*There are 2 in the rear of the intake manifold but one should already be connected to the bypass valve and the other should be plugged or connected to a boost gauge.
*There is also one on the bottom for the brake boost.
2.
I gapped my copper plugs at .40
Discussion Starter · #6 ·
thank you for your help. since mine has 4 nipples i didnt use any t's so now i have four hoses to connect.
1 - 6 of 6 Posts
