the issue i have is the lack of a working blower and thus, no heat.
its Chicago and winter so any help would be greatly appreciated.
Car:
2000 Focus SE
Symptoms:
A/C works
recirculating air works
back window defrost works
blower does not function on any level of speed.
I have:
replaced the blower switch which got the AC working and was needed.
removed and hooked the blower up to the engine and it works fine.
replaced the resistor pack (1st thing i did).
checked all fuses.
i have nothing to show for it.
in my own research it would seem that the lack of speed 4 suggests that the resistor is not the problem and that it is a relay problem. However, I have also read that the relay does not function this way and all 4 speeds run through this particular resistor pack.
suffice it to say, i am confused.
I figure you've all heard this time and time again but every time i find an answer it leads me on a wild goose chase.
please help me fix my car. I prefer to learn by doing rather than paying some guy to do it for me.
also, i am perfectly familiar with testing the circuits via multimeter. I do not work on car electrical systems and would need some help as to where to test (signal flow, etc)
Thanks again
-Nate
Car:
2000 Focus SE
Symptoms:
A/C works
I have:
checked all fuses.
Thanks again
-Nate
