That valve looks like the problem. Honestly, at this point, you're better off finding a 2.5l to toss in there. I applaud anyone who takes the timing cover and head off with the engine in the car. Getting it all back together would be a nightmare. I'm not sure about the rings being bad, but you should clean off the cylinder walls and inspect for irregular wear. You should have a cross hatching effect and no vertical or horizontal grooves. Pull the rods and pistons, hone the cylinders, then install rods and pistons with new rings. You can do that with the engine in the car but getting the timing cover on with RTV and having no leaks would be the hardest part.
As for that chipped valve, yeah, replace that for sure. I suppose that broken bit could have scored the cylinder walls and is causing oil to push into the combustion chamber. In that case, anyone will tell you to replace the engine. A direct 2.3 replacement is more expensive than an upgrade to a 2.5.
