1 - 7 of 7 Posts
i put in a stage one clutch a few months ago and now i'm hearing a noise once and a while after i dump my clutch or shift hard. it's kind of a squeeky noise that i cant figure out. there are no leaks from the slave cylinder. my clutch angauges awasome but i hate the squeek. it wierd because after a while the squeek goes away after im hard on the clutch so it doesnt make any sence to me. all i know is that it is very annoying on race night! any help would be great
did you happen to get any lube on the clutch disc or pressure plate, did you lube your throught bearing
i did everything by the book, i made sure to keep the disc and pressure plate clean and i put in a new throwout bearing too. but the noise isn't coming from the tranny itself, it's coming from the pedal assembly.
might be clutch return spring noise
i have this exact same problem. just installed the stage 1 and my pedal is making this annoying springy sound.
1 - 7 of 7 Posts
