It wasn't a good day ...
I had been intermittently smelling burnt oil and thought maybe the valve cover gasket had failed again. The gasket looked fine, but I noticed oil was leaking around the PCV valve and valve grommet. I had replaced the valve previously at 100K miles and have 147K on the car now.
From other posts on the forum, I am told it is unlikely to have a leak here, but I could have a valve cover gasket leak. And a shop told me I have a valve cover gasket and an oil pan gasket leak. I don't see any visible valve cover gasket leakage. I do see oil on the oil pan and pan bolts seeping down onto the exhaust.
I called the Ford dealer to see if he had a PCV grommet and he said it was only part of a $500 oil-air separator, but he recommended I replace the valve (again) first, so I got a $2 valve from O'Reilly auto parts. (O'Reilly didn't have or show a way to get the grommet or the PCV hose.)
I took the old valve out, but when I tried to install the new one, the right-angle hose above the valve snapped off. (It seemed to break right at the barb for the metal line, but I didn't try to take the remaining part of the hose off.)
I thought this would be a major vacuum leak, but the car started and ran fine, so I'm thinking the system might have other issues.
I put the new valve in and put the broken hose piece on it - I considered duct-taping it, but wanted to ask on here first ...
I am not sure where the other end of the hose goes. (It was hard to see under the coil pack.) The Chilton's book says it goes to the air box, but I think that hose goes to the top of the valve cover. I think the hose turns toward the center of the car and goes to the intake manifold with an odd band clamp on it.
I confirmed that on here and also verified that it is collapsed at the intake manifold elbow.
Reference Posts:
http://www.focusfanatics.com/forum/showthread.php?t=190218
http://www.focusfanatics.com/forum/showthread.php?t=315711&page=2
General Questions:
PCV Questions:
Valve Cover Gasket Questions:
The valve cover was replaced at 114K miles - 30K miles and 3.5 years ago. (Although I checked and the dealer replaced the original one at 48K miles, so this would be Number 4 for the engine). I used a Fel-Pro gasket which isn't popular on here, although that's what all the parts stores sell and all the repair shops use.
Oil Pan Gasket Questions:
There is oil around the oil pan bolts, so I assume the gasket is leaking. However, there is never oil on the driveway and the dipstick stays full. I'm tempted to leave this alone, but ... (I'm also caught with the fact that it doesn't make sense to do this anytime other than when an oil change is being done also.)
Thanks in advance!!!
Reference Posts:
General Questions:
- How can I easily tell what is causing the oil smell (valve cover gasket, oil pan gasket, or PCV Hose)?
- Is it normal for the car to run fine with basically an open PCV hose connection (not open, blocked)?
PCV Questions:
- Other than the PCV system not cleaning the oil - is it safe to do nothing and leave the car this way (which is tempting)? (My gut feeling is the hose is collapsed, so I could basically throw away the PCV Valve at this point and not affect anything. OTOH, if I cut off the bad hose and can't replace everything upstream of it, I'll have problems.)
- What is the best way to fix this? From other posts on here, it looks like motorcraft sells a better intake hose and the PCV angle. They would be $26.28 shipped from Tasca or RockAuto sells a Dorman 46030 which looks like the same parts (both hoses) and would be $18.19 shipped. If I am going to have to get the VCG or the oil pan gasket, I'd rather get everything from RockAuto to save on shipping. (Normally, I know MC is better than Dorman, but this likely failed 50K miles ago, and I only noticed it b/c of oil leaking on the PCV Valve, which makes me wonder why I'm bothering to fix it.)
- It looks like this is pretty much a work on from underneath and look down from up top and work blind job - although I can remove the air intake hose from the air box to the throttle body if needed to gain access.
- Even though I read a post saying to use a 4-inch screwdriver, I'm still not sure how to remove the clamp from the hose. (???) I suppose if nothing else, I can cut it with some snips.
- Not sure whether to try to re-use the OEM clamp or just use a worm clamp? Gut feeling is just use a worm clamp. Deeper gut feeling is this is a vacuum connection, so the force should be pushing the hose onto the connection and no clamp should really be needed.
- Is there any way to replace the PCV grommet on the oil-air separator? (Without buying or finding an oil-air separator?) (Should this even concern me?)
- How can I verify if/that the gasket is leaking?
- Should these typically fail at 30-50K miles, or did I probably not do something correctly last time? Does better quality last longer?
- Originally, I thought the grommets for these were talking about spark plug grommets. I realized later that it means grommets under the bolts (like on Honda's). My car doesn't have these. I assume there is no reason to try to use them?
- Prices on RockAuto range from $10.27 for a DNJ to $28.79 for a Victor-Reinz. How much should I spend and how do I know which brands are decent?
- Rock Auto only appears to have the Fel-Pro one of these for $12.63. They have a Victor Reinz, but it doesn't quite look right and looks like it only goes inside or outside of the bolts and not around them. Is this correct and is the Fel-Pro one okay to use? (I'd prefer not to use a form-in-place RTV gasket like the Chilton's book recommends).
- How difficult is this task to do in a driveway without removing the catalytic converter? (My main concern is the car isn't giving me issues now, even if it has a minor leak. I don't want to attempt to repair it and end up with a worse problem?
- Is it as simple as remove the pan, scrape off the old gasket material, put the new gasket on the pan, and bolt it back together? (I realize there is a bolt tightening sequence in the Chilton manual). (The same book that says the PCV valve goes to the air filter box ...)
- Is there anything else to do or check for with the pan removed (clean out the inside of the pan, etc)? Is there anything serious to watch out for that could be damaged?
- Is there any reason to change the upper gasket while doing this? (In for a penny, in for a pound?) (I am assuming to change the upper gasket if it ever did leak, I would have to remove the pan and change its gasket again to do so?)
