1 - 14 of 14 Posts
this doesnt really belong in here but this is were most of the smarter ppl are.
so with that said
i need help with datalogging on my pc with the X3, i downloaded the livelink but it cant connect with the x3 it keep saying "Failed to connect with device"
i dont understand why iv tryed everything in the troubleshoot "help" file.
Follow these steps:
1. Connect the xcal to your obd II port
2. Connect the usb cable to your PC
3. Turn key on but do not start vehicle
4. Open Livelink
5. Configure items to datalog
6. Start vehicle and click green button to begin datalogging
will it only work in that order?
also i just tried to update it and it said "failed to write bulk data. Device #0"
aahhhhh i dont know whats going on with this thing. it still works and loads tunes on the car.
What did you try to update? The xcal or livelink? That's how it is with the Xcal II. Here look at this and follow the instructions for datalogging.
http://www.sctflash.com/PDF/X3_SF3Manual.pdf
On the Xcal II the key MUST be turned on before you open livelink or it won't read the xcal.
You can go here:
http://www.sctflash.com/techsupport.php
and make sure you have the most updated and CORRECT software. LiveLink for the Xcal2 and X3 are different.
Discussion Starter · #5 ·
alright i got it to update. i didnt have the drivers installed for the x3 i thought i did. i had to go thru and manually load the drivers. so all is good there ill try out ur little 6 step list tomorrow and hope that works.
Double check that manual for datalogging setup. It may be slightly different for the X3 but I doubt it. I read your OP wrong and thought you were using the Xcal2.
Good luck!
Discussion Starter · #7 ·
i got it all hooked up and it works. but it wont desplay the info. i selected battery voltage and coolant temp and things like that but it wont show on the livelink when i click the green box?
every thing is comunicating the x3 says there is a connection detected
Discussion Starter · #9 ·
no. it doesnt show anywhere. just a bunch of zeros
Discussion Starter · #11 ·
i just downloaded it from sctflash yesterday so im sure its the newest version.
and which com port do i need to use?
The reason I ask is because there are different versions for the Xcal 2 and for Windows XP & Vista. Just make sure yours is version 4.41.
To check the COM Port do this:
1. Plug your X3 into your PC via USB
2. Open "My Computer"
3. On the left side you will see "System Tasks"
4. Select "View system information"
5. Click the "Hardware" tab
6. Select "Device Manager"
7. Towards the bottom you will see "Ports (COM & LPT)," click the +
8. You should see something like this "USB Serial Port (COM5)"
When you open LiveLink select the correct Port with the drop down menu towards the top.
Discussion Starter · #13 ·
i dont see "usb serial port" all i see is communications port (com1)
i dont have any other com ports so that isnt the problem????
When you see that unplug the X3 from your PC and if "Communications Port (COM1)" goes away then that is the port your X3 is connected to. Plug it back in to see if it pops back up. If it says COM1 then make sure you use COM1 in livelink.
1 - 14 of 14 Posts
