1 - 2 of 2 Posts
Hi, I have a 2012 Ford Focus HB Titanium and I have gone to my wits end trying to figure out why the right low beam is out, I added LED bulbs and they worked just fine for a week and then the passengers side just went out. I have taken the left side headlight and the stock bulbs and switched them to the passengers side to test with no luck. Replace the foot well fuse at 74.
You probably need to clear codes in BCM it disabled the passenger side because it's seen a drop in current flow so it thought it was open due to the lower current draw the LED headlamps use (your best bet would be to use a relay harness OR use CANbus-compatible LED lights)
Sent from my SM-N960U using Tapatalk
1 - 2 of 2 Posts
