21 - 35 of 35 Posts
FF PHOTOG ENTHUSIAST
So, I am interested in your front Brake assembly ... is that 150 for both Driver and Passenger or 150 Each?
And again, to reiterate, is that for the Whole Assembly per side? IF so, how do the rotors look?
Ray
WhiteSTguy
Discussion Starter #29
Ok want to get it moved so everything left, I'd sell for $500, sans the Yakima rack in the original post.
WhiteSTguy
Discussion Starter #30
Buy everything left for $400. Really want to get this out. I havnt had much time to be going to the other side of town to pick parts. Would just rather sell everything whole. I really hoped someone could use a decent clean title shell.
PCV setup for sale?? I really only need the canister.
PM me if so. Thanks.
Started a new thread since I could' edit my old one. Mods please close/lock the other one.
Parting out my 2004 Comp Orange SVT 3 door. PM/reply for interests. Paypal prefered but cash/local pickup will get priority. None of my prices includes shipping unless otherwise noted. I will try my best to keep updated and reply promptly. I'm working lots of hours and have a newborn at home so there may be a delay in responses so I'll apologize in advance. My locations is 44035 if you want to pickup.
All pictures will be posted to my photobucket album. Click here for pictures.
SVT Focus Part Out Slideshow by OrangeSVTguy | Photobucket
Stuff For Sale:
Yakima full rack setup, Q-towers, stretch kit for hatchback, Q104 clips, 48" bars, 38" fairing 6 SKS key cores plus keys, hullraiser kayak mount. $350 for whole kit
Calipers painted orange but could be repainted/beadblasted
$150 front - fronts come with knuckles/drilled/slotted rotors calipers pads
$200 rear - rears come with whole assembly with newer rotors/brake pads, can include the slotted/drilled rotors that match the front ebrake cables
$300 for full brake setup front a rear
6 speed getrag transmission $200 - counter weight removed but will include with sale(include used clutch/flywheel below for free)
SVT shift knob $10 leather removed
SVT shifter w/ leather boot $40
SVT pedals $40 clutch cover fell off
updated TSB luk clutch and flywheel less than 50k miles on clutch/flywheel $40
Everything needed to do a manual getrag swap $300
Bare shell with clean and clear title $300 - $800? For everything left on the car?
rear hatch carpet $10
starter $40
Zx3/ZX5 hatchback tail lights $40 both
leather SVT parking brake handle $20
Distributor $15
SVT center console $40 - one cup insert missing, also a 120v plug/switch was mounted in the back, no inverter tho.
Rear seat glass windows $25 each side tinted
sunroof track assembly and glass with extra motor $100
headliner $50
AC vents modded with orange LEDs $15
SVT steering wheel $40 +$25 with airbag
passenger airbag $25
Airbag module $25
SVT door sills $20
SVT main wiring harness no cuts $100
SVT glossy door pillars $20
SVT drive axles $20 each
SVT 16" spare tire $20
SVT MAF sensor $10
SVT radiator with dual fans - needs new drain plug $25 - little bent when I hit a tire retread on the highway but never leaked
passenger side door handle $10 (driver broke but can be epoxied, include for free)
SVT alternator (needs rebuilt soon?) $25
power steering pump $20
hatch cover $20
ECU, PATS module and all key locks, door, hatch ignition with the 2 original keys and keyfobs with chips and whatever else needed? $300
SVT coolant reservoir with Orange painted cover $20
8 SVT fuel injectors $25
SVT Fuel injectors harness $35
Gas cap and fuel door $5 each
Dash board with glove box $100
SVT fuel pump $100
Pending:
Driver door w/ tinted glass $100 or $75 without glass
Passenger door w/ tinted glass $100 or $75 without glass
SVT steering rack $120
Stuff that sold below, if it's not listed here I most likely still it so reply or PM
Full interior Recaro black leather/power heated seats and leather door cards $1200 SOLD
Full SVT exhaust from cat to tip $50 SOLD
Roush front bumper SOLD
Roush side skirts SOLD
SVT power/heated/folding mirrors $100 SOLD
European grille SOLD
Rearview mirror SOLD
Brand new never installed LUK clutch and pressure plate $135 shipped SOLD
A-pillar dual pod black with volt & air/fuel autometer gauges. $75 SOLD
SVT Cat $150 SOLD
Mach HIDs $300 SOLD
Wingswest whale tail with brake LED (crack on side been there since I bought it 8 years ago) $300
radio bezel with ash tray $15 modified for double din
Rear hatch door with tinted glass $200
17" TSW Xenons sumisoto tires are junk $150
Stock orange hood $50 lots of rock chips
SVT HVAC silver controls $25
Upper radiator support $25
SVT header $100
16" zx3 6 spokes good winter Pirelli $150
SVT throttle body $40
SVT IMRC $100
Battery few years old from NAPA $40
both front fenders with VW side markers decent condition, driver has damage lower door side $15 each
hood
AEM Cold air intake - lower mount bracket broken some wear marks $25
SVT wire spark plug cover
SVT gauge cluster and aux gauges 127,000 miles $100
Audiophile speakers and sub/carpet/amp wiring if needed? $100
Adapter to use steering wheel controls for aftermarket stereo and stock sub $50
Battery tray with battery cover,(not pictured) strap was cut $20
SVT rear bumper $100
horns
SVT front and rear sway bars $50 for both
SVT stock suspension front and rear springs and shocks $40
dual stage intake manifold $100
Code:
[B]Shipping via USPS Priority:[/B]
[B]Small Flat Rate Box[/B]
$5.80
8-5/8" x 5-3/8" x 1-5/8" Inside
8-11/16" x 5-7/16" x 1-3/4" Outside
[B]Medium Flat Rate Boxes[/B]
$12.35
11" x 8-1/2" x 5-1/2" Inside
11-1/4" x 8-3/4" x 6" Outside
13-5/8" x 11-7/8" x 3-3/8" Inside
14" x 12" x 3-1/2" Outside
[B]Large Flat Rate Boxes[/B]
$17.45
12" x 12" x 5-1/2" Inside
12-1/4" x 12-1/4" x 6" Outside
23-11/16" x 11-3/4" x 3" Inside*
24-1/16" x 11-7/8" x 3-1/8" Outside*
do you still have the e brake handle with the boot? how much?
WhiteSTguy
Discussion Starter #35
Sorry car and rest of the parts are gone.
I do still have some stuff for the yakima rack. 48" bars, Q104 clips, 38" fairing and the stretch kit.
21 - 35 of 35 Posts
