1 - 10 of 10 Posts
trying to figure out the part name for the frame part at the back of the front tire that connects to the fender, fender liner, and frame. One side
has rusted and pulled away from the frame-possibly secured by one bolt?
What year and what side? Is this a small right angle bracket? Can you post a pic?
Paul
Hi-thank you. Here are a couple of pictures. It appears an area in back has rusted causing the part to be loose? Other side is fine.
305147
305148
Pretty sure that is solid unibody there. The part #2 in pic I believe anchors the #5 and not that one.
The lowest fender attaches at the foremost outrigger which is part of the entire unibody.
Thanks again-do you have the part name for #2 and #5 in your image?
Not my image, therefor I do not know where it came from.
That area should be part of the rocker assembly. It’s also right where the A pillar meets the rocker. Your best bet might be to get a used “section” from a salvage yard. Either a used rocker assembly or a used A puller should include the sections in question. If you want new, just confirm with the dealer that the section needed is included with the rocker assembly.
Discussion Starter #10
Thank you.
1 - 10 of 10 Posts
