1 - 10 of 10 Posts
Hello everybody,
First time poster, long time lurker. I am working on changing out my catalytic converter on my 2012 focus se (90+k). I am currently shopping around for replacement and I came across the pacesetter 752044.
It's not "made" for my year focus but I think I am seeing people bolt headers for mk2 to the mk3. Anyone have any insight if this would work?
I am trying to keep it legal and cheap, fyi.
Thanks for any help guys,
Drew
Sent from my SM-G920V using Tapatalk
Hello everybody,
Drew
Generally headers for the MKII do fit the MKIII but the flex pipe will be hitting the frame of the car, if I remember correctly.
Thanks for that info. Has anyone else seen an option to keep the cat but isn't oem?
#dailydriven
MagnaFlow makes a oem replacement. All the performance headers are catless
Sent from my SM-G920T using Tapatalk
Thanks Jburks, I saw that out there as well, but the price I saw seemed a bit out of reach. My budget is tight. If I go with a header then I'll need a tune to get the check engine light off, right? So is that like a prepackaged thing, like plug and play?
#dailydriven
A tune is definitely recommended with a header. They are seperate though. A header and tune will be about the same cost as that oem MagnaFlow manifold.
Old Phart
If you found a 'maniCAT' replacement for a MkII type cheaper than the Magnaflow replacement one for the MkIII it MAY be able to be fitted and work, but likely to have a close interference issue like the aftermarket performance headers mentioned.
No solid info. since I haven't seen anyone post on doing this.
IDK if any inexpensive replacements have been made yet for the MkIII, since it isn't old enough yet to create a large demand.
Discussion Starter #8
Hmmm, I'm thinking I might as well go for a header setup and find some way around the CEL to pass inspection.
Or you could replace the cats with high flow cats. It's a pain in the ass tho to decat our stock headers from what ive heard
1 - 10 of 10 Posts
