1 - 20 of 45 Posts
2007 Ford Focus S
Just bought the car on the 23th of September for a daily commuter. I can't leave things alone so I am sure it will find its way into some form of racing. Car is a 2007 S 5pd. Ran real rough on the test drive. Shaking/vibrating with a wheel noise.
307927
Found that the passenger side motor mount was trash. Also the steel wheels had to go. Picked up 16x7 Sparco Terra wheels wrapped in 205/50R-16 Hankook Ventus V2 from TireRack.
307928
Next I ordered new motor mounts from FSwerks. These are the VFengineering mounts. I also picked up some Autolite 103s.
307929
Next mods I ordered were two guage pods from Ortiz Custom Pods. Steering column and air vent. Should be getting here in a few days. Will be picking up a wideband and tachometer from autometer. And so it begins.......
2007 Ford Focus S
Discussion Starter · #2 ·
Wheel noise was actually the drivers side wheel bearing. Thought it was going to be an easy job. Found that the bearing fused to the half shaft. Had to cut it and replace the knuckle and half shaft.
2007 Ford Focus S
Installed all of the motor mounts. Definitely not as smooth as the rubber stock mounts. I get a little vibration but not near as bad as when the passenger side mount ruptured. The spark plugs definitely gave it a little juice back. I was having trouble getting on the freeway before.
307931
307932
307933
2007 Ford Focus S
Discussion Starter · #5 ·
While I wait for my pods I went to the salvage yard and picked up a new grill as someone did a bad job trying to paint the original.
308064
308065
308067
2007 Ford Focus S
Discussion Starter · #6 ·
Got my gauge pods in. They are pretty sweet. The rpm guage is nicely centered in the cluster and I can see mph great. Wiring the tach was a little work but it came out good. Took me 3.5 hrs.
308164
308165
308166
308167
308168
308169
308170
2007 Ford Focus S
Discussion Starter · #7 ·
Just did the cold air intake. Did not realize how much crap the stock box had. Tomorrow I will probably install the FSWERKS race exhaust and EBC rotors and pads for the front.
308172
308173
2007 Ford Focus S
Discussion Starter · #8 ·
Out with the old and in with the new. The race header should be here tomorrow and I will install a high flow converter where the second converter was located. Brakes install will be tomorrow or Tuesday.
308177
2007 Ford Focus S
Discussion Starter · #9 ·
Added a XFO 100 cell catalytic converter to stay in compliance with SCCA STS rules. Soon as I get my base tune from Tom I will install the FSWERKS header.
308222
308223
2007 Ford Focus S
Discussion Starter · #10 ·
Put some fresh head lights in. Starting to look pretty good. Got base tune in from Tom. Header is going in. Hopefully it not too crazy with the converter in. I have a cone silencer if it is too much. Out with the old and in with the new.
308235
308236
308237
Cool! Since it's a commuter, I would look for the Ford Racing springs and shocks. You also may want to change the upper motor mounts back to stock, the little vibrations that the poly mounts cause will drive you crazy. DIY short shifter is really cheap, and makes the car more fun to drive (if it's a stick). I went and bought all new suspension arms off of RockAuto that came with all new rubber bushings...that will help tighten up the suspension a little bit. After that, get a good alignment. Do the balance shaft delete while you have the oil pan off.
Man, I got to get me another ZX3; I miss mine. Forgot how easy they are to mod!
2007 Ford Focus S
Discussion Starter · #13 ·
I have custom coilovers from Ksport being made (their AR coilovers). Should arrive in a week or two. Motor mounts dont bother me at all. I thought about a short shifter but it honestly feels fine at the height it is at. For autocross I will pretty much be in second the whole time. Track days wont be for a bit and they don't offer any asphalt rallies near me so it will be a while before I need to bang gears faster.
2007 Ford Focus S
Discussion Starter · #14 ·
Also looking at new components from massive for the suspension as I do the rear disk conversion.
2007 Ford Focus S
Discussion Starter · #15 ·
Just cam in the mail. Asphault Rally coilovers from K-Sport. Once I finish up finals I will be throwing these on along with my rotors and pads.
308505
2007 Ford Focus S
Discussion Starter · #18 ·
Suspension and brakes done. Can't wait for the suspension to settle so I can start dialing it in. After that PAC Man will be ready to eat at the autocross events.
308570
2007 Ford Focus S
Discussion Starter · #20 · (Edited)
First race of the season with ABQ Super Lap time attack series. Currently sitting at 5th. First time at this track and first time out in Pacman. Field is extremely tight. First place is sitting at a 1:42 and I am currently at 1:45. I also had a 225 pound weight ballast named RD Blades on that run and 500 treadwear daily driver tires. Only going to get faster with my Falken RT660s mounted for the next round. Time to let Pacman eat!
ABQ Super Lap Challenge Round 1 Results
Z Class:
1st Zack Lopez 1.32.7- 25 Points
2nd Eric Williams 1.33.3- 18 Points '20 Ford Mustang GT
3rd Nick Chiesa 1.34.0- 15 Points '18 Chevy Camero
4th Malcom Jeffers 1.34.5- 12 Points '16 Ford Mustang GT
5th Cabel 1.35.4- 6 Points
6th Tre Panagos 1.36.4- 3 Points '20 Corvette C8
7th Richard Rivera 1.36.5- 3 Points '06 Subaru STI
8th Al Neives 1.37.7- 3 Points '17 Golf R
9th Serinio Nepomuceno 1.38.5- 3 Points
10th Justin Gadell 1.41.7- 3 Points '91 Honda CRX
11th Jim Massy 1.42.3- 3 Points '20 Shelby GT350
12th Keaton Foster 1.43.7- 3 Points
13th Rogelio Ramirez 1.44.8- 3 Points
14th Geoff White 1.49.6- 3 Points
Y Class:
1st Bryan Singer 1.34.2- 25 Points '01 Honda S2000
2nd Steve Harmon 1.35.8- 18 Points '01 Honda S2000
3rd Nate Kappen 1.36.3- 15 Points '90 Mazda Miata NA
4th Brian Baca 1.37.0- 12 Points '09 Mazda Miata NC
5th Darell Randolph 1.39.8- 6 Points '07 Honda Civic Si
6th Maximillian Mayer 1.40.1- 3 Points '95 Ford Mustang GT
7th Gary Mayfield 1.45.3- 3 Points '09 Volkswagen GTI
8th David Beggio 1.48.0- 3 Points '05 Ford Mustang GT
9th Tracy Gadell 1.55.0- 3 Points '02 Honda S2000
X Class:
1st Aaron Montoya 1.42.9- 25 Points '08 Saturn Sky
2nd Daniel Pedroza 1.43.5- 18 Points '91 Mazda Miata
3rd Logan Baca 1.43.6- 15 Points '15 Mazda 3
4th Charlie Till 1.44.0- 12 Points '10 Mazda 3
5th Rowdy Spears 1.45.9- 9 Points '07 Ford Focus
6th Matt Winters 1.47.3- 6 Points '90 Honda Civic
7th Bradin Roybal 1.52.3- 3 Points
8th Josh Campbell 1.53.3- 3 Points '97 Mazda Miata NA
9th Vincent Belotti 1.56.9- 3 Points '90 Honda CRX
1 - 20 of 45 Posts
