Good news.
When I replaced the spark plugs, I noticed the valve cover valley had oil in it. It was coming from the VCT solenoid. So this time, when I had the shop install the 67mm TB and new struts / springs all around, I said I wanted the solenoid replaced. I figured along with an oil leak, having a hydraulic system leaking that operated the camshaft could not be good. When they took off the solenoid, it was in two pieces. It literally fell apart. The replacement was a one piece unit.
Changed the TB with Tom's updated tune. Changed the trans fluid also.
Dang, what a difference! Unfortunately I can't say what made the most difference; the tune, the TB or the solenoid. But I'm sure it's all three. Shows the importance of having everything in prime running condition before playing with aftermarket items.
Flat hauls butt! What's really interesting is I can drive in 6th @ 2000 RPM and it performs fine. Not that is how I drive, I was just checking. Because before it would surge at 2500-3500 RPM in 4th. But WOT felt fine.
Now there's a lot more power in the car. I'm extremely happy and thanks Tom for offering support. I have to ask where the rev limiter is now set because it's higher than 7200 now! I've had it to 7700 according to the tach and it didn't cut the RPM. And it still is not laying down. So just how high can you take these for maximum acceleration and not damaging the engine?
And the rear struts were shot and the front had worn springs. The ride height is higher all around (I put new Ford Motorsport SVT replacements in). Handles better and doesn't scrape the right front on a hard corner anymore.
This is a really fun car!
