Read the code first, you may have this:
P1504 - Idle Air Control (IAC) Circuit Malfunction
This DTC is set when the PCM detects an electrical load failure on the IAC output circuit.
IAC circuit open
VPWR to IAC solenoid open
IAC circuit short to PWR
IAC circuit short to GND
Damaged IAC valve
Damaged PCM
The IAC solenoid resistance is from 6 to 13 ohms.
Probably the IAC, but it could also be a problem with the wiring to the IAC.
