Car started right up. Checked voltage at battery terminals was 12.08.
If the voltage was measured with the car running, 12.08V is low.
The alternator is computer controlled right? and the battery only charges when it calls for it?
The voltage regulator within the alternator itself determines the voltage output of the alternator. The alternator must consistently put out a voltage greater than that of the battery
under all conditions in order to keep the battery charged. The amount of voltage the alternator puts out varies depending on electrical load but it's typically 13.0 - 14.5V.
And it should throw a code for that? I am stumped here. I ordered a new alternator and am in need of diagrams to do the replace.
Depending on the type of problem, the PCM may log a DTC code. More typically, the battery light on the dash will light, intermittently at first and then permanently.
Before you replace the alt, you should eliminate the simple less costly causes: poor electrical connections, broken or chafed wires, possible shorts or corroded batter terminal connections. On some models, there is also a large fusible link within the thick red alternator to battery cable.
Purely guessing, I'd suggest this: Your alternator may be fine (no dash light) but you may have blown a fuse or have a loose cable somewhere (no appreciable alt voltage output). The MAF sensor may be the source of a dead short.
Did all your problem start when your MAF code came up? If so, fix the obvious first then re-assess and proceed with the next steps.
