1 - 3 of 3 Posts
Have 2012 Focus Titanium, threw check engine light code P0420. Checked the cat converter temp, it’s ok. The O2 sensor after cat shows stable voltage between 0.5-0.7 volts. The upstream sensor showed 0volts. So I replaced the upstream sensor and erased the code. Warmed the car up to operation temperature, and the new sensor still shows 0 volts, and no response to throttle. After driving for about an hour same code came back. What could it be?
Did you consider that your catalytic converter is bad? You mentioned temperature; should be about 100 degrees Fahrenheit difference between the inlet and outlet (hotter) when the car is at operating temperature. I think this is what you were saying but just in case.
Is it possible you have an exhaust leak between the manifold and the catalytic converter? This will cause a P0420.
Regarding the upstream O2 sensor voltage; perhaps your connector or wire harness has an issue. You can you use a new wire to bypass the original to test.
my 14 se catalyst grenade itself around 70k miles. might worth being replaced. in the 45k miles I owned my car only things that ive replaced on this car will be the axles, right front wheel bearing engine mounts, and a clutch(knackered release bearing) and the catalyst.
1 - 3 of 3 Posts
