H
Hornpipe2
·Guest
Took my 2001 Focus SE (DOHC) to Advance Auto Parts today because I have idling / low power / stumbling with a check engine light. The clerk used the code scanner and found a P0301 and P0304 - i.e. misfires in cylinders 1 and 4. He recommended a new ignition coil, at $80.
Now I'm no auto mechanic but it seems to me that if there's a problem with the cylinders firing, the first thing to do would be to check the spark plugs. I don't remember the last time I had mine changed but it is definitely over 15,000 miles ago...
If you were troubleshooting this issue, where would you start?
