1 - 2 of 2 Posts
I have a 2003 ZX3 with the Zetec.This code popped up a couple of weeks ago. I changed my plugs at about 40,000 when i had a plug break. So I figured at 115,000 it may need a tune up, so i changed the plugs wires coil pack, as well as the MAF. Well the CEL came back the yesterday when i was stuck in traffic at idle. So I checked the plugs and inspected the wires. They all look fine. So does anyone know what else could be causing this code.
vac leaks can cause lean misfire too.. or it could be fuel delivery issues causing lean misfire.. like a clogged fuel filter? check it out..
1 - 2 of 2 Posts
