Another week, another CEL
Replaced rear oxygen sensor a few weeks ago after P0141 code. That cleared the CEL for about a week until I got another CEL. Check codes and if I remember correctly the first check was just for code P0135 (front sensor). I clear the code and check again a few days later, the code is for both P0135 and P0141. This time I checked and the underhood fuse is blown. A few questions:
1. I'm pretty sure I purchased the correct rear sensor - DY1034. It is a bit longer than the one I removed, and checking on amazon, its listed as not compatible, so I wanted to confirm DY1034 is the correct sensor?
2. Could just a bad front sensor be causing the fuse to blow, resulting in both codes now? Is it highly suspicious the front went after just replacing the rear? Front is DY1040, correct?
Thanks!
Thanks!
