Good evening everyone:
Well here is my question:
My focus did not come equipped with a tachometer.So basically I have been shifting by ear.So far, it has been ok.Typically when I want to power-shift I do so by shifting right before the 30 mph mark on first gear from there I can extend second gear to 50-55 mph. Now tonight, I tried to get out of the hole and try the limits and revved the engine on first gear close to 35 mph.I went to shift right at 35 when I felt a power cut off, which leads me to believe that I had actually hit the rev-limiter.I do NOT want to over rev my engine, but then again getting a tach is going to run me for what i have seen close to 300 dollars (since i need the ford tach driver and chances are will need to get either the ford racing tach or the autometer which both work with the ford racing tach driver).I would like to know about other focus owners here think and also if i can get confirmation as to the numbers in mph I have been using are correct or in fact im going overboard with my power shifting mph numbers.Please, any input will be appreciated!!>
