QUOTE
the fact of the matter is my car never gets leaner than I have tuned it for it ALWAYS gets richer. even though It is tuned for 12:1 in 5th gear it still touches down into the 10s and when it is heat soaked, in the 10s. so if I tuned it in the 10s where would it be in 5th gear?.... breaking up!
In the SCT software you have a WOT fuel target table lets say you put in 12.1 (SCT uses lamda) as stated above and have your MTF set corectly there would be NO WAY for the target fuel to change and go RICHER by 2+ full AF points , The harder you run an engine the more heat it sets up the MORE fuel that is needed to keep the engine safe and in WOT the ECU does not use the o2 sensors for fueling so there is nothing to add more fuel to the point of 2+ AF points , and this comes from a tuner at topspeedperformance
Misinfrmation is the worst thing for Foci builders because some people read this stuff and dont know
