1 - 3 of 3 Posts
I'm nearing the end of my break in period.
Was first run for 100 miles with valvoline conventional motor oil 10w30.
Then changed out with valvoline conventional 5w30.
What weight oil should i Run on a normal basis?
i run 10w-30 year round
FF Affiliate
Oils these days are much better then 10 years ago , I like the synthetic oils and with the turbo and the heat the oils goes through going through the turbo I use a 50wt in the summer and a 30 wt in the winter a lot depends on how often you change the oil and how often you beat on the engine ,
1 - 3 of 3 Posts
