1 - 6 of 6 Posts
I have the header off and I have access to the oil separator and believe that I have a gasket for it.
I don't see any indication that it is leaking etc. I read that the part fails and is no longer available.
What am I looking for as far as a failed part? Should I bother to replace the gasket if I have one handy or just leave it alone.
Thanks.
What sort of paint would you use? I have some vht but baking it is somewhat of a pain. Anything else hold up to that heat? Will rustoleum 500 degree engine paint work?
I decided to go with VHT paint. I'll just bake it and roll. Never have had it peel like other people. Not using primer seems to be the trick.
1 - 6 of 6 Posts
