Just curious is to what the oil pressure should be on these cars when hot and idling. Sat in traffic after a solid 40 min highway drive. Oil started flickering for about 15 min while I just stopped. Then evantually it just stayed on. The engine remained quite so it wasn't starving for oil. I replaced the pressure no luck. Oil pressure test revealed I was making 4psi at hot idle. My car also idles low...600-675 rpm and don't know why. If the light is on and I shift to neutral or park oil pressure goes up a few pounds and the light shuts off.
Has a new ford oil pump too
03 focus spi motor
03 focus spi motor
